Quick question for folks, I am setting up a winch on my jk and am curious about needed in second battery. Should I set up 2 batteries or get one hd battery? Which would serve me better, I don't do crazy rock crawling, it would be incase I get stuck on some trails or if someone else got stuck. Thanks!
If u r only using it once in a while, I'd say a yellow top should be good. Just make sure to keep a set of jumper cables just incase so whoever u r pulling out can boost u after if needed.
Bryce
You don't need a second battery for a winch, second batteries or for running accessories when you car is off, like boat. I you just have a winch I would worry about battery up grades, but it depends how many accessories your running even then I would upgrade the alternator
