I have a 4 door 2007 JK
My Right Rear window will not roll down.
What I've tried:
-I swapped doors with the left rear to test if it was a car side electrical issue, and not getting signal to the window.The window switch operates the left rear door window fine.
-I then assumed it was the motor that went bad. Bought a new motor, and it still doesn't work.
I am afraid its the door side harnes... The wires go far deep inside the door. The door does not look like its meant to be taken apart.
Does anyone have instruction on how to replace the door side wiring harness? Any other test's I can do?
Thanks
If the right hand switch operated the left door when tested and you've replaced the motor
(assuming the replacement isn't defective) the problem must be between the plug and motor somewhere.
I'd have a close look at the plug it's self for loose or damaged connections.
