Not sure if anyone has had this same issue but I was hoping for some insight/info. The 08 Wrangler I bought in May was missing one of the 2 screws/bolts that are in the A pillar underneath the windshield, I went to a local Jeep dealership to get a replacement, figured they'd wouldn't be cheap but wanted to keep it stock. Apparently the prior owner had a set of light brackets installed and screwed up the threads. I picked up some lights and brackets, repaired the threads with a helicoil and went to the drivers side, removed one bolt but unfortunately the other one just turns.....is there an easy way to get that bolt out without scratching the paint or reeming it out to were I can't do another helicoil? Just curious if anyone has had the same issue
^ No need to be harsh on it...
Yes, when you fold down the windshield there's a nut on the backside.
