While replacing the hinges on my windshield I had to drill out several of the bolts. While doing this I broke out one of the side nuts mounted to the inside and knocked the two nut bracket loose on the front of the windshield. Any advice on how to replace the side nut and how to put the bracket back in place and bolt up the hinge? Your thoughts and ideas are greatly appreciated.
Been there you will have to get longer bolts and put nuts on the inside its hard to get up in thee but it can be done I taped two wrenches together and the tape the nut in the wrench to hold it while u thread the bolt a second set of hands would help
