Just installed a hardtop wiring kit on my JKU but it seems that the washer pump is backwards when spraying. Spraying front will spray the back, and spraying back will spray the front.
Anything in particular I should look at? I was hoping the dealer reconfiguration would fix it (last step in the installation instructions) but it didn't. I just swapped the hoses so it would work correctly - but it secretly bothers me.
I normally understand and sympathize with minor annoyances and try to help. But in your case everything's working 100% right but might not be out of the right pump So live with your upgrade. I guarantee the rear pump has less use time so if it is now the front, that's technically a win. Right?
Why would that bother you? The hoses are on wrong.
Swapping them will fix it, as you already found out.
Directions are probably screwed up.
Enjoy your new hardtop, hope it doesn't leak.
Your new hardtop ;)
That's all it is.
Just because the pump says R[ear] and F[ront]. In the end I don't care - but it's an "issue" I'm aware of. And that's why it bothers me. What doesn't leak :)
If the control plugs are the same, swap them, then revert the hoses.
