Had to drill out a couple winshield bracket torx bolts, anyone know where i can get replacements? thanks
Rock-Rubber
Replace them with flat Phillips head bolts. Ace Hardware has them. For future reference, use heat first and you won't have to drill them out.
X2. just take one of the bolts in with you, they can thread match so you are buying the right one. Or you can just check off a nut in the store that works. Alot of hardware stores should have them.
