How hard is it to change out the windshield wiper motor and what all is entailed in doing it? What is the easiest way to get to it?
Locate and remove the cover on the frame. There is an e-clip which is a PIA to get in/out and then the linkage is snapped together you will see it and the fitting is plastic. Once you go to reinstall that plastic bushing should be lubed with some grease light grease and then you have to snap it back in place which can be a PIA. I used a socket that fit and hit it once with a hammer to overcome the pressure to snap it back in. The e-clip will take a few minuts of patience.
