1 - 17 of 17 Posts
The front wipers will not stop even if the key is off and out. I pulled all the plug on the computer. The switch I removed all of the plugs still going. I got a new motor still going. :banghead: I could use some help here
2007 Unliminted Saraha 4 door
Show Me Your 8008135!
If the motors are wired directly to the battery through a relay...I bet the relay went bad and is stuck in the on position. If that's the case, pull the relay and replace it before you need your wipers again.
Where the relay I cannot find it in the fuse panel
Honestly have no idea... that's just the best explanation I could come up with based on the info in your post.
On my TJ, all my relays are in a box next to the battery under the hood...I'd guess yours are in a similar location.
Sorry not relays in this model. It really getting to me. I am usally am able to figure this stuff out. I currently ran a switch to my fuse and installed a in line fuse. I dont think my wife will let that go very long. I really dont want to take it to a dealer to tell me what it is. They will tell me its the motor and still have a problem. I am not going down that road. If somebody that know their stuff about that model I would really would be very thankful.
There's gotta be relays somewhere...the wipers may be tied into another relay as well so it may not necessarily be labeled as a wiper motor relay.
Any idea where the TIPM is located...seems like that's what the OP is having trouble finding...and since I don't own a JK, I'm not much help in that department.
I don't own a JK either but I've seen that problem before. TIPM is the black box near the battery that has all the mini fuses.
Discussion Starter · #12 ·
Still no luck, I talked to the jeep techs. They told me to unplug the tipm by the front driver side. It didn't make a difference. They also told me their is only one tipm. Relays for the wipers are built into the tipm. Tell me this does the fuse to the wiper should that always be hot or does it only get hot when it gets power:banghead::banghead::banghead::banghead::banghead::banghead::banghead:
What worked for me was to turn the wiper switch all the way on quickly then all the way off, all in the span of one wipe. Then they quit. Almost as if you can't use the blinker and wiper arm switches all the way...just a light tap (downward) gets three blinks and one wipe, respectively.
You guys seem to not understand how the can bus system works
With a can bus many components always have power
For example the radio gets fused battery power at all times
What controls when it is on and off is the TIPM
The TIPM sends a digital can bus signal to the radio to turn it on
The reason it only works with key or key fob is the the wireless ignition module and key or fob chip reader sends a digital can bus signal to TIPM to tell it key position
When a TIPM strays to fail almost any item can turn on or off on its own as the TIPM she senses switch’s like headlight or turn signal then TIPM not switch sends power to components
First pull the wiper fuse to get it to stop
Next you have to decide if TIPM is bad or park feature on wiper motor failed
1 - 17 of 17 Posts
