Are you just looking for an entry point into the cabin? I routed my switch wiring through this hole near the brake booster. Just punched a small hole in the thin foam plug and fished the wiring into the interior.
^^^^ what they said.
If you look at the firewall from under the dash on the driver's side, way up in the left upper corner you can see what looks like a round rubber grommet. It's actually more like a piece of tape on the inside, and a sort of foam type stuff on the outside.
It's easy to find, and easy to poke some wires through the hole, from there it's just a matter of routing and securing them to your liking.
Good luck
Exco
There is also a spot on the passenger side, behind the insulation. Poke a wire down at an angle and you will be right behind the glove box. By the way, take the glove box out, it gives a ton of room for making connections and keeping things hidden. I found that spot by watching a SPOD video on youtube.
