1 - 10 of 10 Posts
I have a Pioneer AVH-x5500BHS head unit and I'm installing a backup camera. The radio has a feature to view the camera while in any gear, not just reverse. So I need a constant power source. I had planned on using the reverse light wiring on the tail light, but it's not constantly on.
Are any of the wires going to the tail light constantly being powered? Or will I just need to find another source?
Retired Mod
You got 3 choices IMO.
1. Leave it as is...
2. Tap the 12V outlet at the front of the vehicle (which is switched).
3. Tap the 12V outlet in the rear of the vehicle. Wrangler's with the premium sound system have a 12V outlet in the rear. I hear that even if you don't have the 12V outlet, the wiring is still there behind the passenger side panel. The only issue with tapping that power source is that it is always hot. So if you tap it, your camera will be on 24 hours a day, 7 days a week. Not sure what kinda of draw it has (battery wise), but it is something to think about. I also don't know if the camera would ever overheat.
I do need to double check that rear outlet. I know that on my Libby, I could run my air compressor without even putting the key in the ignition from the rear outlet and I thought my Wrangler was the same way.
I'm sure there is another switched power source to tap, but I don't know where it would be.
Retired Mod
^Owners manual is useless.
It says the outlet in the dash is switched, the outlet in the center console is always hot, and that there is a 3rd outlet available if you have the premium system. It does not say if it is switched or not. If I remember to do so when I leave work tonight, I can plug in my air compressor (without a key in the ignition) to see if it is hot or not.
That would be the thing to do. And please report what you find, I'd like to know that myself.
Retired Mod
I ran out and checked during lunch...that rear 12V outlet is indeed hot....so I would not tap that source unless you are OK with your camera being powered 24 hours a day.
My b/u cam is wired to the running lights in the back rear tail light, so the lights have to be switched on for it to work.
Well, mine is actually a little wifi unit wire into the tail light...but that's another story.
Had a local car audio shop do it for $50.
Discussion Starter #8
Looks like I will probably just run back up to the head unit. I was hoping to keep the wires in the back to keep from having to run back through the jeep, but looks like I may have to.
Thanks guys.
Retired Mod
Looks like I will probably just run back up to the head unit. I was hoping to keep the wires in the back to keep from having to run back through the jepe, but if I may have to.
Thanks guys.
LOL...I know exactly how you feel.
I have a non-mirror image license plate cam that I will use as a baby cam (valcro'd to the roll bar)...but I have not installed it because I just don't feel like running the wires from the rear to the front. Not that is is "hard"....but it is just tedius.
You did it once for the RCA cable on the back up camers....and you just don't feel like doing it again.
Discussion Starter #10
Exactly lol
1 - 10 of 10 Posts
