Ladies & Gentlemen I humbly beg for your help.
I disconnected the 3 wires on the voice command microphone (pic from another post below but doesn't show wire placement) when swapping from a 130n to a 730n & would like to beg someone to tell me which wires go where originally (I took a photo but my flash caused it to be all white damnit).
It sounds like the 130n -> 730n update is plug & play, yet I started to follow the 2011 update (link below) & unhooked the microphone & without the pic I am really hosed.
http://www.wranglerforum.com/f274/wiring-uconnect-microphone-from-130-430n-to-730n-118131.html
Thanks to everyone!
ps everything except voice is indeed working great.
Anyone? I basically just need to know the placement of the 3 wires on that harness so if you're planning on taking out your 2014 JKU stereo please post a pic of the wire placement!
Sweet site, thanks for the link. It was close to giving me what I need, but it doesn't show the pin layout for the 3 wires on the 10pin mic set.
Looks like I was wrong, found it on there!
Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you Thank you
RADIO C1 BASE
Mopar Package #: 05135638AA
Cav Circuit Gauge Color Function A1 X712 20 DG/LB MICROPHONE 1 IN (+) A1 X703 22 DG/OR LEFT AUDIO OUTPUT A2 X712 20 DG/LB MICROPHONE 1 IN (+) A2 X704 22 DG/YL RIGHT AUDIO OUTPUT A3 N0 N/A
NO CONNECT A4 X793 22 DG/YL MICROPHONE FEED A5 N0 N/A
NO CONNECT A6 X795 22 DG COMMON AUDIO OUTPUT A7 X792 20 GY MICROPHONE IN (-) A8 X792 20 GY MICROPHONE IN (-) A9 N0 N/A
NO CONNECT A10 N0 N/A
NO CONNECT
