need intsructions for wiring horn(by-passing column steering wheel). any advise or instruction would be helpful....
The horn circuit is generally just completing the ground circuit thru a relay. You need to fill out your profile so someone can tell you what wire it is. In general terms all you have to do is find the right colored wire, run it to a horn button and run the other side to a ground. That will work on most any car.
Good luck!
