Going to be wiring two Hanma 2x2 LED lights this week and need to build a harness.
I could use a little help with some parts of it.
1. What size relay do I need? Are there different amperages?
2. I am going to fuse the power from the battery to the relay, what size fuse should I use?
3. Should I fuse the hot side of the switch too? If so, what size fuse there?
4. Where do I get power to the switch at? The battery as well?
Thanks!
Thanks!
