Help please. I can't get it.
Going from a red black white illuminated switch that comes with the wiring harness to a lighted locking plasma glow type switch. I've blown 2 fuses. The directions are crap.
Appreciate your help.
Do you have a multi-meter? Use it to test the continuity with your wires so you will know the pinout of you switch.
Solution
Ok here's the solution for the 3 wire to the 5 pin switch.
I like it.
Top is for the light bar.
Bottom Blue are the rock lights.
Black to Black
Red to the Green
White to the Blue and Red
If you want the LED to turn on when the Relay or Light is on:
Black = Ground
Green = Hot [C]
Blue & Red = Relay Trigger [NO] & [LED B+]
Yellow = not used [NC]
Edit - Sorry, you posted while I was writing.
API-ELE switch 16mm
This wiring is for the 16mm API-ELE locking switch.
