1 - 15 of 15 Posts
My ACE rear bumper/carrier is supposed to be delivered Monday. I have the stock fog lights for it and want to install them to BOTH come on with the reverse lights AND as a seperate switch. So, 2 questions, how is this done and where is the best place to run the wires, along the frame rail underneath? or get them into the cab and run along the side? I searched but didnt find anything specific.
I've been called alot of things but never a Nobody. LOL
I would use plastic loom and run the wires up the passenger side of the frame.
You could use the factory wire to the backup lights to control a relay for the fogs.
I'm guessing that will be the easiest, plus I already have the plastic loom. Now if I can figure out exactly how to install the lights as I want them....
I do my own stunts.
For the ground, there's an existing grounding screw in the rear driver side corner behind the bumper.
I ran my positive wire underneath the bottom driver side corner of the tailgate weatherstripping to the interior. From there I tapped the driver side backup light wire for it to go on with the backup lights, then I tapped the positive wire to run another positive wire along the inside, underneath the carpeting, through the firewall, to my sPOD for switched control.
Aside from the point, I eventually removed the tap on the backup light because 1)the lights were too bright and annoying for most on-road backup situations, and 2)I didn't want the bulbs to burn out so quickly since they're difficult to replace, at least on my setup.
You will need a three way switch and prosperous wired relay. I had this on a few of my vehicles. Look at PIAA backup lights, and their instructions specifically. The wiring diagram should show you exactly what you need to do
Thanks! UPS is supposed to be here sometime today.:thumb:
Properly ^* not prosperously. Stupid auto correct and stupid proofreader
Discussion Starter · #11 ·
Was wondering what a prosperous relay was.
A prosperous relay is wealthy and has lots of electricity. :D
BTW: Without pics this mod never happens. LOL
Discussion Starter · #13 ·
I better watch out, it could end up being a shocking experience. :zap:
A friend just installed a new stereo and it has a back-up camera option. He wanted to hook that feature up. The instructions say to tap into the back-up light wire to activate the reverse camera. He needs to find the back-up light wire. What color is the back-up light wire and where did you find it?
thanks
1 - 15 of 15 Posts
