Please Help me!!!!! I want to wire my fog lights to the start up only power. I choose to use the ignition power. Are there any visual examples or thorough steps out there I can use as guide?
Knows a couple things...
If you want your fog lights to only be on when you're driving at night and shut off when you shut your headlights off, I would instead power the fog light relay from the low beam wire powering your headlights. Or for driving lights, power the fog light relay from the wire powering the high-beams. Both of those wires are easily accessible behind either head light.
Actually I want to access fog lights via rocker switch only when necessary, hence only when car is on.. wouldn't I need an ignition or aux feed?
