1 - 9 of 9 Posts
Got some new fog lights and need some help on where the the wiring should be. The PO must have took them off, the original sticker he had listed them and the stalk has the switch but i can't find anything around the bumper. Any pics of stock fogs on a 2001?
Dont forget a Jack strap
he might have removed the wireing right at the box? i dont have fog lights .. do they have their own fuse?
If it had stock lights the wires run under the fenders then drop down to the lights .
If your new lights a higher than 55watt. I would not use the stock wiring
They are 55W, found this, looks like they were cut. Is that the right place where they are spliced together?
I looked at mine and it looks like where mine is coming from. Do you have a voltage tester. That would be the best way to know for sure
I do, just finished doing some work on my sliders, so probably tomorow. I got the week off!
1 - 9 of 9 Posts
