1 - 12 of 12 Posts
Hey guys. Last night I went to put my Jeep in 4 wheel and she didn't go in. The Leaver is easier to pull up then my e brake is it feels as if the lever just came disconnected or something. Does anyone have any suggestions as to what it could be or how to fix it.
Administrator
linkage might need adjustment.. there is an adj ment bolt at the end of linkage towards to the side of the t-case... see if that came off or is free floating.. in most case there should be about 1" or less of rod exposed past the adjuster.
Sweet man thanks I'll check that as soon as I get off work and get back to u. Is it on the driver or passenger side of the transfer case.
Administrator
drivers side...
So I crawled underneath n went to check...turns out the whole linkage rod broke off. It was still the stock one on there So I'm gunman get the linkage extension for it.
I just replaced my mechanical with Savvy's cable system and it's a lot smoother. It takes a small amount of fine tuning, but I like it better.
Okay I'll look into it. I have to get heavy duty tie rods n front steering stabilizers then see where I'm sitting on money Cause mechanical is cheaper. lol
1 - 12 of 12 Posts
