I have a 06 jeep wrangler unlimited that will not start. I get power to everything but when I turn the key nothing happens. I have already changed the ignition switch.
Did you have your battery tested? I had the same problem in the past where the headlights, stereo, and other components operated but there wasn't enough juice to initiate the starter.
When you turn the key to start it, nothing happens?? Do you hear any noise at all?? I had something similar happen to me a couple weeks ago in my 2001 TJ. I had all power. Lights, radio, horn, etc. When I turned the key to start, I could hear a relay click, but that was all.
Check out this thread I started, when I was having issues. Should help you narrow it down a bit.
http://www.wranglerforum.com/f210/2001-4-0l-tj-no-crank-no-start-1575497.html
