Battery is good, starter showed no signs of being bad but it wont turn over. Radio and all that works, not showing any codes, 2013 jku, any help at all would be greatly appreciated
Do you hear any clicking or anything? When you attempt to start, aka turn key to start, do you see your headlights dim or dome light dim?
Ideally you'd look at a scan tool and see if the TIPM is getting the start signal from the ignition switch. Without that you can look and see if all the other electrical items dim because power is going to the starter.
Another thing to try is putting a DVOM on the battery and see what the voltage is. Then while starting, see what the voltage drops to.
Clean and tighten battery connections. Don't care how good they look. Clean them.
No go, then come back with voltage measurements.
WF approved Offical Jeep Account.
Hi LegendOfPika,
We’re sorry to hear about this. Please feel free to let us know via private message if you decide to address this with your dealer and we will gladly assist you during that process.
Lydia
Jeep Social Care Specialist
I thought I fixed the problem by replacing the starter, everything was fine for about 3 days and then it's doing the same thing
