Would it be much of a drag to have a stock TJ along for the ride? I'm itchin' to get out with some fellow jeeps.
Your more then welcome to come. Since your stock you will be taking a few by passes. After a few bad groups ive had in the past I got a few rules.
1) You must air down to a min 12 psi. Dont want to air down thats fine but I will sit there drinking my coffee and watch you beat your jeep trying to up trail. I always have my air system and will gladly fill your tires if you do not have one. Airing down is the best way to gain traction.
2) Stay as a group no one wonders off. If your stuck or broke down the whole group stops unless one person is sent out for parts. Before the run begins I will state the route and tails we will be taking. If you have CB channel 22 is the normal unless other wise stated.
3) Only one person spotting. Driver doesn't need 10 people telling him/her different things to do.
4) Im easy on the skinny pedal if you are not and like to Baja up the trail and you break something. Ill be there drinking my coffee watching you fix it. Im not crawling in the mud AGAIN to work on someones jeep cause they didn't wheel smart.
/rant off
