Hi there, 1st and foremost I'm clueless when it comes to this stuff lol so apologies in advance. Found the wheels I want but I'm unsure if they fit my 2016 unlimited willys, same wheel, different measurements confused me so I figured I'd ask you guys and gals. Will be getting a 2.5-3 inch lift soon.
1. Fuel Coupler 20 Black Wheel / Rim 5x5.5 & 5x150 with a -12mm Offset and a 110.3 Hub Bore.
2. Fuel Coupler 20x12 Black Wheel / Rim 5x4.5 & 5x5 with a -44mm Offset and a 78.1 Hub Bore
YOu need a wheel that has a lug pattern that is 5 on 5. 20x12 is a huge wheel and you will run into problems with that wide of a tire. go visit tirerack or discounttiredirect and put in the year and model of your Jeep and they will show you options that will work with it.
