Good day every one.. again a very strange question. do anyone know where is the Horn relay of wrangler. mechanics are not use to this car if anyone can help that be great. My horn stopped working all of a sudden. mechanic says that he needs to check the horn relay but he cannot find out which and where it is.
thank you
So there is no relay its directly connected to Computer
Correct.
As silly as this sounds, try banging on the steering wheel and horn a couple of times. Sometimes that's enough to get things working.
Otherwise, you can try disconnecting the battery for a while to see if that resets things.
Last resort, change out the clockspring.
Correct.
Thank you highly appreciate your feed back
