I have a 99 TJ, I am replacing the D35 with a Ford 8.8 with a SYE and new driveshaft. Once that is complete I plan on working on the D30. Has anyone replaced the stock D30 front axle assembly with a XJ D30? I have a 4.0L Manual transmission with 160K on the jeep. I am running 33's with a 4" lift.
The XJ has a high pinion D30 which is desirable. A lot of people have done it including myself. Unless you find one with the gears you are looking for you will have to re-gear. You can't use your current gear set as a HP30 has reverse cut gears.
It's also easiest to just swap over your axle shafts/unit bearings/rotors. There is a difference in the earlier year models that have a slightly different unit bearing height. Swapping all of your stuff will eliminate any issues. I can't recall what the year range was. You also want to get a non-disconnect axle.
The 8.8 is a 4.10 and my understanding is certain XJ's had 4.10 gearing. Will I need a new driveshaft with the HP30? Just to confirm, all I need to do is swap my D30 axle shafts/unit bearings/rotors and I am done? By the way I used to live in Aurora when my dad was in the AF, I also visited Aurora when I was stationed at Lowry a long time ago.
Most XJs came with 3.55 gears. The XJs that were optioned with the towing package came with 4.10 gears I believe. If you are pulling the axle out from under the XJ and the diff tags are missing or unreadable look inside the Jeep and under the A/C controls there should be toggle switch that says towing. Not sure if all XJs had this but early 90's automatic ones did. The toggle changed the shift points.
Not all xj's are high pinion... 2000? and up have the same low pinion that your tj has
Compatible axles with 4.10 gears can be found in 4 cyl 5 speed tj xj and mj
