1 - 10 of 10 Posts
ok so now i have a new problem. On my way home i hear a clunk noice and suddenly the jeep starts vibrating and making a horrid grinding noise. its in gear but sounds like something is in a bad bind. Does this sound like a U joint or something else?
and to add to it, i also noticed that between grinding noises it sounded like a weird hum somewhat like i was running offroad tires which im not. I figured if the ujoint was bad that might just be the driveshaft vibrating.
Sounds like a u-joint
it was hard to tell. It felt like the vibration was coming from just behind my seat.
i will checking when it stops pouring rain
Banned
Sounds like you will need to crawl underneath the rig to confirm or eliminate possible causes. Until you do that, IMO, there's too many options to pin point a solution online.
yell tell me bout it. this thing has been nothing but trouble since i bought it in july. What else could make that noise just out of curiousity
1 - 10 of 10 Posts
