1 - 20 of 46 Posts
Discussion Starter #1 (Edited by Moderator)
We torn down jeep and remove the engine differential etc and will replace it with a y60 engine (td42) and differentials from a 94 nissan patrol safari
Discussion Starter #2
Thinking of 37-38 tires
Reactions: MTJeepTJ
Yj build philippines
Got the engine, diffs etc. from a y60
Image from inet
Actual pic
Td42 engine and differential
I am putting up a 37-38" tires im thinking what would be the best wheel base for this build. its has to be drivable on the streets and hard trail. Should i retain the original wheel base? For the jeep to be stable and capable of climbing
Discussion Starter #7
Cleaned, painted and replaced the worn parts of the engine and trany before mounting it to the jeep.
Discussion Starter #8
Nounting the engine with the tranny.
Nissan patrol y60 seems to have big transmission
Engine bay still has room
Welded the engine support brackets
Reactions: J33P
Where's the Balut and San Miguel? LOL
Reactions: try2gofast
Discussion Starter #11
We custom made a cross member to fit and support the transmission. It has a portal design for the propeller and additional strength
Discussion Starter #13
This inspired me. Got it from a friends magazine.
As of now 06/20/2017
My mechanic suggests a two link with a panhard (stock configuration of a patrol) to hold the differential. Dont have any idea on this. Maybe you guys have a design on this and are the air shocks good for this?
Discussion Starter #14
Got the link from a land cruiser fj40. What do you think?
Looks good to me, it going to be a great Rig when done!
Discussion Starter #16
Well this is pretty freaking cool.
Discussion Starter #18
Buikd is slowing down, too busy on work
Power steering, brake, and clutch lines installed
Next is fuel lines
Reactions: MTJeepTJ
I see you're back at it with another build. Good for you!
I sure hope the Jeep body was level before using a level to cut. I've seen people make that mistake with bus conversions!
1 - 20 of 46 Posts
