1 - 17 of 17 Posts
hi folks as my name says im new to jeeps but not mechanical builds so i do have some abilities just not specific knowelage i need. i recently purchased a 1995 wrangler and its a high milage and needs alot of parts replaced eventually. heres my first question. if i want to replace the dana 35/30 with a set of strong front and rear ends where do i start? i know rearends are findable in junkyards ut im sure some are better than others. meaning front ends from certain trucks. which are closest to the width i need and such? also where do i find the proper brackets to weld onto the new rear ends to match the yj? sorry so may questions im just trying to narrow it down so i can find parts to rebuild dureing the winter here in iowa.
thanks randy
More info on your jeep and your overall goals would be helpful. Auto or manual? Expected tire size.... you get the idea
ok. im not looking for huge tires. maybe 35's 33's for sure. im live in iowa and we dont have rocks to climb just mud and snow. the jeep has a ton of miles so im going to have to go through the entire drive train eventually. it has a 4cyl now though im not against going with a 6 cyl or v 8. actually thats another question. with mudding being my best chance of offroading im thing the 4 cyl wont cut it without gearing it to the sky. now it has a 5 speed manual though if i do a switch im leaning towards a 700r4. i wont need the jeep for daily transportation but want to be able to drive it on the streets from time to time without following behind it with a trailer. A rough draft of my uneducated plan would be 4.3 v6, 700r4, widest set of 33's i could find because i prefer the look of wider tires. as i said just rough draft
Founder, ThumbJeeps
^ yup. If you want to run 35's for tires you'll want to go w/ford 8.8... a lot depends on your engine as well. If its got a 4 cylinder, only lift it 2" and go with 31's... otherwise you can do almost anything lol
Welcome to the forum!
a ford 8.8 with a factory 4.10 and your stock d30 front (as long as its 4.10 as well) would be good with 33's....if u put a bigger motor in.
so if i was to consider a 8.8 what would it preferably be from? 5.0 mustang or f series? point being i have no plans to "go big" but i could see a chance of a v 8 in the future. also my thought process is even though i have no plans to "go big" just yet i am going to have to go through the entire drivetrain as i said so with that thought would the 8.8 be a good idea since i have to rebuild both ends anyway? cost ways is it close enough to go ahead and go for it now or just keep the 30/35? sory ive started out makeing such long posts.
look for one out of a explorer or mountianeer something like 95-00 with disc brakes. If youre going to do anything to the d35 replace it. the d30 is a good (and free since you already have it) option for the front because if you find the 8.8 with a 4.10 you dont have to don anything to it.
thanks alot. i dont mean to keep asking and asking but lets say i find me a rear end which shouldnt be a problem. where do i find the brackets and spring mounts at? ive looked around but honestly there is SOOO much jeep stuff its overwhelming to start out. thanks again
Keep reading on here, these guy's know their stuff....
Teraflex sells a kit with every thing u need perches e brake hook up and adapter for the pinion
if you want to change the entire drive train you could probably buy an entire truck with the running gear you want that has a bad body for less than you can buy the individual parts
I agree. I just bought an 87 K-5 Blazer with a fuel injected 350. No title, but I got it for $500.00 and drove it home :thumb:
If you plan to keep the 4 banger just go with the 8.8 and keep cost down. You can get the perches from Morris4x4.com, Jeepaddons.com, e-bay, etc.
You can do plenty of mudding with a good set of tires and lockers on the 4 banger. My 90 model has 4.88 gears, with 33" tires, lincoln-locked rear and the stock Dana 35. I can go where bigger trucks cannot in mud. The Dana 35 is not the best axle, but I have always had good luck with them, so I am not going to trash talk it too bad.
Discussion Starter · #15 ·
thanks guys. im gld to know i have a few options to consider. im looking forward to spending alot of hours reading and reading this forum to learn all i can. thanks again
M.O.R.E. has a lot of stuff to put a 8.8 in a YJ. Read up on them a lot of people say to weld the housing to the axles, have it done by a professional and save yourself some headaches down the road. The D35/8.8 is a great combo.
1 - 17 of 17 Posts
