Ok, bought some half doors for my cj got the piece for the latch on the door opening. But is there a easy way to locate this and will I have to cut away much metal? Thanks
COLLINS BROS used to offer a bolt on adapter striker bolt for used on earlier tubs, otherwise you need to weld in the brace that holds the striker bracket.
Thanks, modified yj striker to fit cj it's riveted in right now. If they work ok I'll put a couple of tack welds on it
