Found an old yj hardtop cheap and put it on my TJ saturday. 15 degrees out but sunny. Taped off about 1 1/4 inch on the front that meets the header, did one cut and one trim then put it on and it fit fairly well. Used self tapping screws on the header seal, drilled the cap to match the tub and done, about 2 hrs. Too damn cold to do any finish work. Just another job waiting for warmer weather.
good way to re-purpose an old hard top.
if it were not for the different windshield angle (TJ windshields are tilted back at a higher angle than YJ windshields) the two tops would interchange much easier.
