Can you leave the front track on top of the windshield for the soft tops when installing the hard top. I have a hard top on now but thinking of getting a bikini top to switch back and forth just wouldn't want to have to take the track on and off and leave open holes. Thanks.
Well dang, anybody come up with some type of way to get around it or an easy way to deal with this?
A phillips head screwdriver is the easiest way
Attach the upper soft top bikini rail with screws and use a power screwdriver.
When you put your hard top back on, fill each screw hole with a dab of clear silicone.
If your hard top seal is in good condition, the silicone in the holes may be overkill, but better safe than sorry.
Good Luck, L.M.
Reactions: Jak_Rak
