1 - 20 of 260 Posts
Retired Moderator
Just wondering how YJ owners are doing with mileage, like who has the highest or whatever. My 94 yj 4.0 only has 106,000 on it so it's just getting broke in. No problems except a vacuum leak I need to get after. How's evreryone elses YJs holding up?
The TJ guys are making us look bad, so get to posting.
Hello all,
Speedy here -- just came over from swbjeep.off-road.com.
I've got a '95 Wrangler Sahara Edition. Bought it bone stock in 2000 with 143000kms.
Now its got 215000kms, and since then I've added
MSD ignition (now removed)
Accel Coil (now removed)
8.5mm wires
triple core all steel radiator
K&N Air Filter
Turbo City Intake
Turbo City oversized throttle body
3/8" throttle body spacer
Random Technologies hi-flow cat (now hollow)
Turbo City cat-back exhaust
2.5" OME Lift Kit (now flat front springs after fender-bener
Xenon 6.5" Fender flares
15x10 Pro-Comp Mud Terrains
Pioneer CD Player
12 speakers, 2amps, roughly 1300 watts
Kentrol stainless steel hinges, hood treatment, mirrors, etc.
Stainless Steel grill cover
I have purchased but not installed:
Warn 8257 winch (not the -50) off of ebay
Stainless Steel light bar with 5 KC Daylighters (150watt)
In the near future I plan to:
replace the cat (emissions test)
replace the rad (again)
maybee add a Banks header and downpipe
At some point I need to:
re-gear to 4.11/4.27 and add lockers (Ox?)
Bumpers, front with winch mount, rear with tire carrier
Cheers,
Speedy
Retired Moderator
Welcome Speedy. Just curious. Whay do you use metric and you are in Boston? I'm only wondering.
I'm really a fan of this forum her. I'm glad those guys put this one together. It's starting to pick up nicely. Tghe other forums had gotten old to me. I was tired of having to sift through all kinds of vehicles to get to SWB Jeeps.
Everybody here so far appears to have good humor, too. That's really cool.
Jerry
I was wondering if the kms would catch anyone's attention. I'm Canadian, eh! Originally from Nova Scotia, I was living in Ontario when I purchased the Jeep (its got kms on the odometer). After a short detour in Chicago, I've been in Boston for 4 years now.
My interests are deeply divided between my Harley and my jeep -- I don't seem to have enough time or money for both. Every once in a while I go on a spending spree and upgrade tho.
This seems like a good forum so far. swbjeep has been dying a slow death these past few years, but I've been spending a lot of time on some motorcycle forums, so I haven't noticed much ;)
Speedy
I got mine in 2000 with only 62K on it. Not bad for a then 13 year old Jeep. Now it is old enough to vote and has 93K. I have done a lot of work but it has never let me down. Everything I have done was upgraded not repaired, except for the Carter carb. That was upgraded because it needed fixed.
94YJ 4cyl, 132,000 Miles.
Daily Driver
31x10.5 BFG MT's
1 1/4 shackle lift
Nothing but Routine maintinence so far. Lacking a little power, but think it's normal due to miles and 31's. Just starting to battle the RUST!
i have a 89 yj with 203k miles on it! and still running thru the dunes strong. only addition is a custom light bar and shackle lift to run 31's. got luv the jeep!
93,000 miles
i have a 95 yj 4cyl 5 speed bought stock in may of o4 with 107,000mi now has 120,000mi. now it has 4 1/2" bds lift 33" tires w/ micky thompson classic lock rims. 9,000lb tabor winch ,lock right locker in the rear, posi lock in the front. i do have a detroit ez locker for the front but need to install it at some point. its a fun toy to off road and oh yea i get 17-20 mpg just dont use 5th gear. my daily driver.
Retired Moderator
94 Yj
Ah another 94 YJ! I managed to score a 4.0L with 55,000 miles on it four weeks ago. Guy had bought if from a friend for his daughter to run back and forth to Cal Poly. 20k in the last 5 years and no underside scars. Completely stock except for a few spots from battery acid from a botched change by her ex-boyfriend.
Her loss -- my gain.
Awaiting delivery of a RE 2.5 lift kit. Tires and wheels to follow.
Retired Moderator
Discussion Starter · #18 ·
Excellent. I'm glad to see another YJer on this board. Stick around. The TJ guys try to gang up on us and we can't let them get away with it.
amerijepp
AMEN !! 5th gear eats up gas in mine too and i get about 15 to 20 a gallon with 4" and 31's hoping my snorkle increases it a little( ram air ) :D it did for my CJ
1 - 20 of 260 Posts
