101 - 119 of 119 Posts
Thought I'd post my 88 project...I bought it over the summer as a non-running project. The P.O. had installed the rear half (the easy half) of a 2.5" trailmaster lift and had "custom built" a snowplow. I removed the plow to get access to the front end, installed the other half of the lift, installed the TC drop the P.O. also included. Got it running and moving under its own power. While installing new brakes and brake lines all around, I discovered the rear backing plates were so rotted and the axle was trash, so got a replacement from the junk yard and replaced seals and bearings before installing it. Replaced all the bushings and u-joints up front and converted the column shift automatic to a floor shift (because all the linkage mounting points under the hood had rotted away). Removed the seats and started repairing the floor cancer and then winter came. I picked up a free set of 31X10.50's mounted on custom wheels. 3 of 4 tires are junk but I'll get new tires mounted on the stock wheels in the spring. Still much to do but here's how it sits as of today...
4472315
My 94 YJ,
"Frankenstein" (Frank for short)
4475433
4475435
4475436
4475437
Replaced:
all floor pans,
Rhino Bed-liner the entire inside
New interior
New top
Sliding 1/2 windows
Auto-gauge:
GPS Speedo
Tach
Mechanical oil pressure
Mechanical temp
Mammoth Wheels
33" Mickeys
then
1969 Camaro SBC 400 bored 0.30 over
Pushing about 450hp
With a 650 Holley avenger double pumper
95gph Holley fuel pump
Headman headers flowing into dual flowmasters
My 94 YJ,
View attachment 4475433 View attachment 4475435 View attachment 4475436 View attachment 4475437 View attachment 4475433 View attachment 4475435 View attachment 4475436 View attachment 4475437 Replaced:
all floor pans,
New interior
New top
Sliding 1/2 windows
Auto-gauge:
GPS Speedo
Tach
Mechanical temp
Mammoth Wheels
33" Mickeys
then
Pushing about 450hp
Nice Jeep ! You might want to run the numbers on that block to get more accurate information. The 400 wasn't offered in a 69 Camaro. It didn't come out until 1970 and was typically in larger passenger cars and light trucks. If you do any off roading or live near dust I'd replace that air filter.
Not trying to be critical, but I always like as much helpful information as I can get for my own vehicles. I figure others do as well.
Sent from my E6910 using Tapatalk
My 92 YJ 4.0 L 5 speed manual, 5.88 gears, Dana 60 front 14 bolt rear spring over, Currie anti rock sway bar, Bilstein shocks, Chrome molly shafts, Reid knuckles, ARB lockers, Yukon hubs, PSC Hydro steering assist, Atlas Trans 4.3.1, Genright gas tank and flat fenders on 37's 12.5x
4479312
4479313
4479314
17" Raceline bead locks
1995 YJ & 2012 Rubicon 2 door
Took my son out in his ‘95 YJ yesterday. DMV isn’t issuing driver permits right now so practicing off-road.
What wheels you running on this?
92.
Spring over kit, with an extra 2’ish inch of shackle. 35x14.50’s Lock out hub/ 35spline TJ axles up front. 8.8 in rear. 4.56’s with Lockers front and rear, 1 ton steering.
Hey Guy's I am new here to the forums, "So a big shout out to all you jeepers!
4514481
Did not drive this for some time after I bought it, if you have not noticed the temporary plate in the window. What I did while it was setting here; New bumper, winch, quick disconect on sway bar, off road lighting, grill and light trim, hood vent, "Ok, before you tell me its on backwards, (I like the vent that way) LOL
Very soon, this jeep is going to lose its fenders, flares, rock guards, rock sliders, and corner guards, I am sure something else will come off down the road, hopefully not by accident, lol. Going to replace everything from front to rear with Metalcloak. I am so excited, just waiting for it all to get here!:p
4514729
1990 2.5 5spd, 4" springs, 1.25" boomerang shackles, stock jk wheels 255/75-17 bfg mud terrain t/a, webber 32/36 carb, duraspark ignition, (renix TBI is GONE!), Odessa ported head w/1.7 rockers, steel horse targa top w/sunroof, cad delete, home made front and rear bumpers, front is 4" schedule 40 steam pipe and ar500 target steel welded to the frame, rear is 4"x2" structural steel beam and bumperettes.
