I've been on this forum reading alot of these threads when zero oil pressure at idle.
I have zero oil pressure at idle when engine is warm, I have done a compression test on all cylinders they have all passed. I have done a radiator compression test this has passed. Changed out my oil sensor in the engine block and I have hooked up a manual gauge for my oil pressure. When I start my jeep up when it is cold, I have good oil pressure and everything sounds right, but as it reaches 210' my oil pressure drops to zero. I have changed my oil 4 times (using 10W30). And I have also checked my CMP and replaced it.
Do I need to replace my oil pump or am I missing a step?
Any info would be greatly appreciated, thanks
