Hey everyone! New guy to the forum!
I have a 2k Wrangler with the IL6, and I have zero oil pressure. First I thought the sending unit was bad - replaced it. Then I thought the gauge on the dash was bad. So I installed a "mechanical" gauge, and it still reads zero pressure. It runs smooth, doesn't make weird noises and doesn't over heat. I'm stumped. Suggestions?
Full Size Jeep Dr.
Did you install the mechanical gauge in the cab, or in the engine compartment?
Try installing it with the electric sender and see what it reads. You might need to flush the oil passages some and then see what it reads.
