1 - 14 of 14 Posts
So recently one of my zippers broke off my back window and I went to an upholstery store and they're being to difficult so I was wondering if there are kits or individual zippers that I can buy. Also any tips on how to make taking them off go smoother. All I heard before is using like a candle wax. Anything helps, I appreciate it fellow jeepers!
had a zipper broken once. used para cord to replace. it worked great. plus its cheap and easy.
If it's just the little handle thing that you pull that broke off, do what I do... Every time I go to take the windows off slip a ziptie through the little hook on the actual zipper part and use then to pull and cut it off once you put em back on so you don't have a ziptie flapping in the wind lol.
And also, wd40 works good to lube up the zippers and make go a little smoother.
Light coating on teeth. Buy a new slider, open gap enough to slip on the teeth, then crimp it closed with pliers. Just make sure it faces the same direction as the original.
Discussion Starter · #12 ·
Thank you, I really appreciate it. I usually have all the windows off anyways but when a dust storm comes in it's nice to be able to close it up
If I get a new zipper can I just zip it right back on...? Someone know an answer to this?
Yes you can put a new slider on. You need a new slider and a clamp on stop. It's a YKK#10. Jeep Zipper Sliders Pry off the old stop, slide on the new slider and crimp on the new stop. Very easy.
1 - 14 of 14 Posts
