I have Zone 3" springs on my TJ, after adding my bumpers, rock sliders and winch, I'm not happy with the ride height. Do I::
1- add a 3/4 to 1" spacer at all 4 corners or
2- or just swap out to 4" springs?
3- recommended springs? I trail ride mostly, some street use but not to often. I wouldn't buy the zone again I don't think.
I would just add the 1.25" Body Lift.
don't like BL, lets you see more frame, plus better suspension is useable off road, BL is not.
Plus I'm swapping my axles so the springs will be out already.
BL def has some advantages, mainly lifting your belly and gas tank skid. but thats another convo
what dont you like about your zone setup?
you could grab 4" front springs
I want a little more clearance now that the armor stuff has weighed it down, want to keep the ride quality though and asking if spacer will change the rates of the spring much over replacing the springs with 4".. all 4 springs not just the fronts, my side rock sliders add weight to the whole jeep and rear bumper is not light either.
