1 - 20 of 151 Posts
I've been doing a lot of research on lifts lately because the wife gave me permission to get a 4" lift on my TJ. As long as I get some side steps on it. Anyways. I've been looking at a lot of lifts and like almost everyone else out there I am on some what of a budget. I found this lift and like what it says, found a lot of threads on it and seems to get some really good reviews. On the other hand I have seen others say they "know someone" who has it and dont like it but never actually found anyone out there that doesnt like it. Also the site says that you dont need a transfer case lowering kit but there are people who dont have it saying you have to have one. Its back and forth and I'm guessing that I'll keep seeing that back and forth answer. But hoping to get some good and bad feedback on this lift so I can make a choice. I really dont want to spend more then $700-$800. And whats CYE? I see some posts saying you need to drop $600 on that and have know idea what it is..
But here's the ling to zone so if someone dont know what it is can look at whats in it and give me some feed back. Thanks guys. 4.25" TJ Combo Lift
Here is the most important info you provided. The problem with most of these 4"+ kits is that it only addresses the suspension. They are many other things (costs) that go along with it...like steering, control arms, and brakes upgrades, SYE (as you mentioned), etc. So what appears to be a $1000 upgrade is actually going to be alot more (like 2X-3X) by the time you are done doing it right/safe.
Read this about the SYE: http://www.rockcrawler.com/techreports/jb_short_sye/index.asp
Looking at the product description it's a 3inch suspension with a 1.25bl. Depending on what he uses his jeep for, this kit should be everything he needs to have a DD/ weekend warrior.
It's definitely not a top of the line kit that's gonna be an offroad beast, but for your DD/ hunting rig/ occasional trail rider it'll get the job done.
Ya, I should have stated what it will be used for.. I'm in South Dakota, the eastern part where there are no trails.. I will be using it for trail riding in the Black Hills which is a 6 hour drive to the west. Will not be "rock crawling" with it but dont mind some of the deep ruts and the mud holes and the nice rougher trails. So ya a weekend warrior will be a good way to put it, but more like a once every 2 month on trail riding. We can get some nasty winters so the higher clearance on the snow will be nice and for some hunting trips in the fall and mudding here and there.
But with a kit like this, can you add the control arms and what not later on? And do they have to be from the same manufacture you get the kit from?
Rock-Rubber
I don't have the kit, but I have the kit if tht makes sense. I have the 3 inch suspension component. However my body lift is from rough country and is essentially the same thing. You more than likely will need the (small) tc drop that is provided. There are ways around that. Temporary is a mml. Eventually you'll want a sye/ cv. Do some more research on those.
You can buy control arms and anything else you think of after wards. And from anyone who makes them. All your buying is a set of springs and shocks and some pucks along with longer bolts and a few brackets and longer sway bar links to keep everything similar to stock.
Because this is not a 4" suspension lift, the sye and everything else you mentioned...wont come into play as a need.
The Zone 4.25" kit is a 3" suspension lift with 1" mml and 1.25" body lift which in most cases eliminates the need for a tcase drop or sye...
I currently have this kit...they originally didnt have it when i got my lift so i first got a 3" suspension lift with tcase drop...great. Has a nice ride on road, does great offroad, and is an overall very nice quality "budget" kit.
I recently added a 1" mml and the 1.25" body lift then removed my tcase drop...i have no vibes and it works great.
I love the kit and recommend it to anyone...
As far as adding stuff later...of course you can. I plan to add adjustable control arms and all that jazz so i can do a full tummy tuck in the near-ish future. You dont need the same brand either. I'll be going with a few different brands when doing my tummy tuck.
but, i love my kit and its been great...zero regrets buying it. Just do yourself a favor and dont put steps on. Get some grab handles and just tell her to pull herself in...steps get hung up on a lot of stuff and make it look lower than it is...
Send Allen a PM at AOR...he'll give you a discounted price on the kit
I have the 4" Zone and I'm very happy with it. Have the tcase drop now but in the future I will be getting the motor mount lift. Then I will remove the tcase drop and add some washers to remove any vibes if they are an issues.
Ok cool. Im excited to lift her up. I have to get the steps. This is the only way I can get a lift. :(
Rock-Rubber
Buy sliders with a built in step. Look up brooks customs bcc they are a vendor here he's on eBay and has affordable ones. 20% off right now. And you can mod them to cost less and be used as a step.
Show Me Your 8008135!
Be careful...I HIGHLY recommend this kit for those on a budget. I have it, it's a great kit.
However, a decent chunk of Jeeps (mine included) have major vibes even with the tcase drop installed...some even have vibes with both the tcase drop and a motor mount lift installed. Mine has very minor vibes with both installed. Basically this means my only real option to 100% solve the problem is to install an SYE which means I'll also have to install adjustable control arms to set the pinion angle...buy a different trackbar bracket for the SYE apparently, and so on...
Basically what I'm saying is...make sure you can afford to swing the cost of an SYE and adjustable control arms (probably $1000+) just in case you end up with major vibes...I bought the MML so I wouldn't have to run the tcase drop. Luckily I did...because I needed the MML along WITH the tcase drop.
Also, I highly recommend purchasing an adjustable trackbar for the front...relocating the hole like Zone recommends will likely end up causing problems down the road due to the hole wallowing out either causing the trackbar to become loose (thus causing death wobble) or causing the entire hole to rip out of the mount (thus potentially causing a major accident when your axle goes one way while your Jeep is going the other). JKS is a good choice if on a budget...Currie is the way to go if you wanna do it the best you can and have a little extra cash to spend.
Also, I second PM'ing Allen (AOR) for your kit. He will give you a MUCH better price than ordering direct from Zone's website. He's a very nice guy and will get you taken care of.
Hey sentenced. What do you mean about a new rear track bar relocation bracket?
I agree with everything you said btw^ :thumb:
There was a thread recently that mentioned when you install an SYE and adjustable control arms, you will also need some special bracket for the rear trackbar that's compatible with the SYE. When you set the pinion angle, you rotate the rear axle which means your trackbar is no longer going to mount properly in the standard bracket provided with the lift kit. You would need to either modify the trackbar (essentially heat it and twist it I think) or replace the bracket.
This was the first I'd ever heard anything about that...but those involved in the discussion were knowledgeable folks so if they said it, I'm inclined to believe it. I'll see if I can find the thread and I'll post it here.
Found it:
http://www.wranglerforum.com/f5/rear-trackbar-bracket-with-sye-enlighten-me-please-135720.html
Rock-Rubber
Found it:
Thanks for the link. Well my trackbar is already twisted. So maybe it'll be perfect after that :rofl: good to know. Something I needed to know for sure
Discussion Starter · #14 ·
O.k. another question about this lift.. First off, I'm not mechanically inclined so I'm looking for someone to put this on. Was talking to a mechanic and he was saying that doing a sus lift and body lift is unsafe? And for some reason was trying to talk me down to a 2in lift.. Ummm. thoughts?
My neighbor and I just put this kit on at the end of Dec during the holiday. Do your self a favor and get the adjustable front trackbar from JKS and a steering stabilizer ... adding these made a world of difference.
If you want someone to install the kit for you make sure you go with someone who knows how to properly install it. The install instructions from Zone are good enough even a rookie could do it with the proper tools. You mentioned a budget so realize the labor is going to be expensive but also if you try to do it yourself the needed tools are also an additional cost.
You didn't mention your tire size, if your going to a 33x12.50 and sticking with your stock rims then your backspacing will be an issue. So you will either need new rims ($130 each) or spacers ($200 for 2 sets).
Thats a stupid comment...
running a suspension lift paired with a 1 or 1.25 body lift is completely safe...having the body lift also allows for you to do a tummy tuck down the line when you do your adjustable arms and whatnot...
Um...no. A HUGE lift will raise the center of gravity, but a 3" lift won't raise it that much...and a small body lift will only slightly raise it compared to a suspension lift.
If you did like a short arm 6" lift...that would probably make it a bit more dangerous.
I can tell you based on real world experience, my Jeep is much more stable and comfortable now at 80mph on the interstate with the 4.25" combo, Cragar Soft 8 wheels, and 33x12.5 tires than it was stock with 31x10.5 tires. Stock, it was almost scary...
Rock-Rubber
X2. And suspension raises everything except axles higher. Body lift only raises the tub. So a body lift raises the cog a lot less.
Discussion Starter · #19 ·
O.k. well that rules out going to this guy. LOL.. For tire size, down the road i'll be going with 33s, but right now i'm using 31s.
You'll be fine, you wont look "too" outta place
I'm currently running 32x11.5's on mine but will run 33x12.5's once these are shot...i also have flat fenders up front and flat flares in the rear (as of this weekend, anyway) so i've got a ton of room with the 32's and will still have a ton with the 33's
As for the step...i agree with the idea mentioned above, get some sliders with a built in step instead of getting the factory ugly bars that get hung up on rocks...i mean factory side steps
1 - 20 of 151 Posts
