Tj97 I'm putting a zone 4" and I already have a sye and slip drive shaft do I still need to drill and put the spacers on thee upper control arm axle mounts ?
What spacers? You need to purchase adjustable rear upper control arms to adjust your pinion angle. The Zone kit you purchased does not include all necessary components required for a 4" lift.
I would not use the cam plates if you're doing an SYE and CV shaft. They require you to drill out that bracket, which then requires you always keep the cam plates or fix the hole you drilled. You will however need adjustable control arms now to properly set your pinion angle.
The cam plates won't adjust your pinion angle enough for an SYE and CV shaft anyway, so throw them in the trash where they belong.
