very easy to do
I replaced my fan with the two speed taurus fan
and I just did a friend brought me his jeep to do the same thing (I installed it yesterday)
I built a custom bracket for the over flow tank
other then that you just trim down the taurus fan shroud to fit
you have to mount the fan upside down for clearance
other then that its easy
and you'll notice more power
heres my buddys jeep that I put the fan in
and pics of the fan
the fuse block I picked up for the fan
the relays right above the fan fuses
and the overflow bracket I showed him what I needed and he cut it out I wouldnt ot used sheet metal but he thinks it will be fine
this is the fan installed in my jeep
and the over flow bracket that I built for my jeep
and heres the fan before the install ( not the best pic but you can see it)
