2020 JL Frequent Key Fob battery drain
1 reading
9.7K views 16 replies 10 participants last post by  Gigabot
I have a 2020 JL and I’m having really annoying key fob issues… they both go out at a frequency of 2-3x/ month!!! I don’t have a problem getting in and starting it when it’s dead, in fact I perfected the routine to minimize the time the alarm is sounding. But I’m tired of it and would like to solve this problem.
Last week I took it to the dealer for the 2nd time in 3 months last week, they kept it for 2 days and couldn’t find an issue. They replaced the battery. He did say that it could be that the batteries I’ve been buying from various stores like Ace Hardware and Amazon and Walmart, might not go through the batteries frequently enough so I could possibly be buying dead batteries. As often as I have had to buy them I don’t think that’s the problem.
I got it back a week ago today and the freaking low battery warning just came on AGAIN tonight. They lasted 1 week!
I do know that if you store the key too close to the vehicle it could drain faster bc they’re constantly signaling each other. I was curious if anyone knew the range/distance of the key. Mine is pretty far and can remote start. If that is the case I’m going to have to store my keys at the neighbors’ house. Thoughts?
My 2018 JL key fobs still have the original batteries in them.
As already mentioned, something in the key fob(s) must be draining the batteries.
Is it happening to both fobs? Have you tried replacing the battery one fob at a time to see if it happens in both?
Good luck.
So many causes to look at. If the stored fobs are close to the parked vehicle the vehicle will constantly search out and consume the fob battery that responds back. Other comments I've read say storage close to a magnetic source will cause it. I would try storing the fobs somewhere else and see if that fixes the problem before buying replacements.
#10 ·
Check the voltage of the batteries when they are supposedly flat and see if they have actually dropped in voltage compared to new ones
Was thinking same thing. Trust the technology. Jeep is telling you the fob battery is low. Pull the battery and put a volt meter on it and see if it is below 3V, and if so, by how much? Not sure what brand or point of purchase your batteries are, but it's not unheard of getting bad stock.
  • Helpful
Reactions: Chugiakguy
#15 ·
How many people don't want to say that the FOB took a little swim with them? It does help others determine what the issue might be. I have two FOBs - my kid took one swimming. I dried it out - put in a new battery(Energizer -Don't buy crappy batteries -that doesn't help the post either)- Boom! back to life...for about a week. Dead. Brand new battery and one week later it is dead again. Other FOB is still fine. So I can conclude it was the water and likely now a short somewhere in the FOB.
#17 ·
ok - opened the Wrangler FOB and removed the casing to to the circuit board. I can see that there is white water damage around some of the circuit board but not tons. But, one pin has corroded through and is gone on the chip(left side in picture below) likely causing the drain. I will keep the FOB around as it will still work if I need it with a new battery.
