After changing the transmission filter on my '01 last year, I had a small leak from the transmission. My understanding is from the factory the 32rh comes with an RTV gasket, but mine already had a rubber gasket so someone in the past had been into it already. At this point, though, I'm on my third gasket I've personally changed, twice with the $15 Fel-Pro and now with a LubeLocker and the leak has gotten progressively worse each time. I've read that the pans are easily warped, but I'm not sure how to tell if mine is or how to straighten it if that's the case. I'm tempted to drop the pan again and try to make a RTV gasket myself, but I've never done that and I'm afraid of getting RTV into the tranny and clogging the valve body. I'd sure appreciate any advice you folks can give, I'm on the verge of (gasp) paying someone to rebuild the thing and solve the leak. Original reason for changing the filter was slipped shifts when it was cold (fluid level was good).
