Hi everyone, I have a guy bring me his jeep to work on. His rear end is an early amc 35 (1989). the pinion bearing came apart and i have order parts and cleaned it up. My question is can a dana 35 pinion shaft work in a amc 35. The reason i ask is the large pinion bearing from the kit is wrong (hm88649) this pinion takes a (hm88648) larger bearing which is the same that is in the dana 35"c".
I am trying to figure out if it came apart because he has swapped parts around or if its something else.
thanks
thanks
