I'm gearing up to install some stuff and picked up a switch panel that goes in front of the shifter.
My ARB compressor came with a rocker switch. I bought a couple more for my driving lights and dash cam.
I ordered them from OTRATTW. When ordering, there's an option to pay a little extra for LED's instead of the default incandescent bulbs so I chose that.
Now that they arrived, I compared them to the switch that came with the ARB compressor and notice that it has incandescent bulbs.
Now... some questions. They're all "lower independent" switches.
Looking at the wiring diagram for them, it appears I can hook up the bottom light to the dash dimmer circuit but that the upper light is powered from the input voltage when the switch is on.
Does this mean that only the lower light is dimmable and that the upper one will be at full brightness whenever the switch is turned on? This seems like it would be annoying at night.
I used a 9 volt battery to try to test it and noticed that the LED's are REALLY bright. Have I made a mistake with those? Should I order new incandescent ones or should I order another LED one to replace the ARB switch?
