Belt routing on my '87 YJ 4.2L with A/C, NOT serpentine
8.2K views 4 replies 3 participants last post by  rustypeevee
Hi everyone,
I'm having trouble finding a diagram to show me the routing for the belts on my YJ. It's a 4.2L with A/C, and it takes three separate V-belts, not a serpentine. I had some "help" and all three belts have been removed. I know I need to buy a Chilton's, but haven't yet. Thank you.
Russ
I've a 87 4.2 with AC. The engine was rebuilt so I can't assure you that it was the factory set up. The belt numbers did not match up so I had to go with what was close. The Alternator belt, I had to get from a lawnmower supply believe it or not.
There are a lot of little things that have lead me to believe that this was a very early 87 YJ with lots of CJ parts.
Good luck
Thanks for all of the input. Got it all figured out now, so here's some info:
For my '87 YJ, this is the belt routing and NAPA #'s for the belts:
If you have all three V-belts off, they need to go on in this order:
1) First belt goes around pulleys for P/S pump, crank, and water pump. NAPA #9465
2) Second belt goes around pulleys for crank, water pump, and A/C compressor. NAPA #7475
3) Third belt goes around pulleys for the alternator and A/C compressor. NAPA #9245
Thanks again,
Russ
