Bilstein Adjustables ???
4K views 9 replies 6 participants last post by  rawlmark
If you are installing longer coils & shocks, why would you choose to install a set of shocks that can be adjusted? (Not a flame against the Bilstein 5100. Just curious.) If you adjust the shocks, wouldn't that hurt the coils over time?
Also 5100 aren't adjustable... I just installed a set this last weekend.
#7 ·
Those are 2 very different adjustments. Ride height adjustment is nothing more than placing the mount point at a different location. Changing the Firmness of the shock would be the other type of adjustment typically consisting of a Valve to vary the pressure inside the shock which the 5100 Series does not do.
#8 ·
Would the different mounting locations already be on the jeep, or would a mounting bracket (with multiple locations) be supplied with the Bilsteins?
