Blank Dash Panel Removal
1 reading
943 views 7 replies 2 participants last post by  68RR
Wanting to replace my HVAC light bulbs now with LED’s. In looking at some YouTube videos, there seems to be three screws holding the large dash panel in place. The third one looks to be hidden under either the factory ash tray, or my blank panel. I’ll attach a picture of what I have, although the picture isn’t mine…pulled it off the internet. How do you remove that blank panel with breaking something?
Thanks!
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the instrument panel top cover from
the instrument panel. See Instrument Panel Top
Cover in this group for the procedures.
(3) Remove the ash receiver from the ash receiver
housing in the lower instrument panel center bezel.
(4) Remove the one screw located in the back of
the ash receiver housing that secures the center
bezel to the lower instrument panel (Fig. 12).
(5) Remove the two screws that secure the center
bezel to the top of the instrument panel.
(6) Using a trim stick or another suitable wide
flat-bladed tool, gently pry the lower edge of the cen-
ter bezel away from the instrument panel.
(7) Lift the lower edge of the center bezel upwards
to release the four snap clip retainers that secure it
to the instrument panel.
(8) Remove the center bezel from the instrument
panel.
(9) Reverse the removal procedures to install.
Tighten the mounting screws to 2.2 N·m (20 in. lbs.).
ACCESSORY SWITCH BEZEL
WARNING: ON VEHICLES EQUIPPED WITH AIR-
BAGS, REFER TO GROUP 8M - PASSIVE
RESTRAINT SYSTEMS BEFORE ATTEMPTING ANY
STEERING WHEEL, STEERING COLUMN, OR
INSTRUMENT PANEL COMPONENT DIAGNOSIS OR
SERVICE. FAILURE TO TAKE THE PROPER PRE-
CAUTIONS COULD RESULT IN ACCIDENTAL AIR-
BAG DEPLOYMENT AND POSSIBLE PERSONAL
INJURY.
cable.
(2) Remove the center bezel from the instrument
panel. See Instrument Panel Center Bezel in this
(3) Remove the four screws that secure the acces-
sory switch bezel to the instrument panel (Fig. 13)
(4) Pull the accessory switch bezel out from the
instrument panel far enough to access the wire har-
ness connectors.
(5) Unplug the wire harness connectors from the
rear of the accessory switches and the cigar lighter/
power outlet.
(6) Remove the accessory switch bezel from the
instrument panel.
(7) Carefully pry the snap retainers at the top and
bottom of the accessory switch (fog lamp switch, rear
window defogger switch, rear wiper and washer
switch) receptacles on the back of the accessory
switch bezel with a small thin-bladed screwdriver
and pull the switches out of the receptacles.
(8) Reverse the removal procedures to install. Be
certain that each of the snap retainers in the recep-
tacles on the back of the accessory switch bezel are
fully engaged with the switches. Tighten the mount-
the picture had a heat control slider (helps if you at least list year of you vehicle)
CENTER BEZEL
REMOVAL
BAGS, DISABLE THE AIRBAG SYSTEM BEFORE
ATTEMPTING ANY STEERING WHEEL, STEERING
COLUMN, OR INSTRUMENT PANEL COMPONENT
DIAGNOSIS OR SERVICE. DISCONNECT AND ISO-
LATE THE BATTERY NEGATIVE (GROUND) CABLE,
THEN WAIT TWO MINUTES FOR THE AIRBAG SYS-
TEM CAPACITOR TO DISCHARGE BEFORE PER-
FORMING FURTHER DIAGNOSIS OR SERVICE. THIS
IS THE ONLY SURE WAY TO DISABLE THE AIRBAG
SYSTEM. FAILURE TO TAKE THE PROPER PRE-
INJURY.
cable.
(2) Remove the top cover from the instrument
panel. (Refer to 23 - BODY/INSTRUMENT PANEL/
TOP COVER - REMOVAL).
Fig. 3 CENTER BEZEL
1 - BEZEL MAT
2 - TOP SCREWS (2)
3 - CENTER BEZEL
(3) Remove the two screws that secure the top of
the center bezel to the top of the instrument panel
structural support. (Fig. 3)
(4) Using a trim stick or another suitable wide
(5) Pull the lower edge of the center bezel away
from the instrument panel far enough to disengage
the four snap clip retainers that secure it to the
receptacles in the instrument panel base trim.
(6) Remove the center bezel from the instrument
panel.
TOP COVER
REMOVAL
INJURY.
cable.
(2) Using a trim stick or another suitable wide
flat-bladed tool, gently pry the instrument panel top
cover up and away from the instrument panel far
enough to disengage the five snap clip retainers from
their receptacles in the instrument panel structural
support (Fig. 16).
Fig. 16 TOP COVER REMOVE/INSTALL
1 - TOP COVER
(3) Remove the top cover from the instrument
panel
