CEL Code P0301 after replacing oil cooler 2014 JKU
7.2K views 19 replies 9 participants last post by  YnotAJeep
Man, looking for a break here, but Jeep threw up the P0301 code after I completed the oil cooler swap on 2014 JKU this week. I had followed others instructions to replace the drivers side plugs while in the engine and immediately thought that was the issue. I opened again and replaced new plugs with original plugs only to continue seeing CEL. I have a replacement fuel injector coming for cylinder 1 tomorrow, but thinking of turning to Jeep service if I cannot resolve. Any ideas about what could be the cause? Followed torque specs, tightening patterns, etc while rebuilding. I did have to touch the fuel rails, injectors and injector wiring during tear down and rebuild, but felt was careful and gentle with wires, etc and cleaned the injectors. Any ideas or suggestions?
Yes, it's the front cylinder on the passenger side. I originally did change the plugs only on the drivers side as they are covered by the intake manifold, but after understanding the P0301 was related to cylinder 1 on the passenger side, I've focused attention there.
I have not tried the coil swap yet, but will try that next. Its interesting that I didn't even touch the coil/plug on the passenger side during the oil cooler replace...if that's the issue.
#13 ·
Tell us more about what you did when you "cleaned the injectors".
#14 ·
Mainly wiped down injector spray base and around where the seals seat. Was surprised by the amount of grit around that section of the lower manifold. I have a new replacement injector that will be going into cylinder 1 tomorrow.
So far, coil pack and new plug at .44 have not resolved code. Inspected the ground wire suggested by jay2011jk and everything looks normal.
In addition to the new injector for tomorrow any other suggestions of what to inspect while I'm in the lower manifold?
