My cowl vent isn't draining well. I tried to clear the drain hose using a running garden hose, as well as by reaching down the drain hose opening with a flexible tool that has little grabbers on the tip for getting hair out of sink drains. I've pulled out a small handful of mud and debris, but it won't drain even though I've been able to reach 13" down the drain hose.
When searching old posts on the this forum, I found some advice to squeeze the bottom end of the hose. Is it pinched shut or capped?
From below, I can see something that looks like an over-ripe banana (circled in yellow in the photo below). I thought I'd check here on the forum before I risk doing any harm (or soaking myself with wet muck). Thanks!
