Nice response. I've also had decades in electrical situations, mostly in TV broadcast vehicles. Know how many electrical connections are in those? I also HATE crimp-on connectors.
Look at ANY push-and-click connector with a magnifier (I use photographer's lupes) and you'll see a LOT of possible contact surface, but very little actual contact. Most of the time the amount of contact is a lot higher than what the to/from wires pass, so they work well. But the contact surface areas/scratches are NOT anywhere NEAR 100% of the possible contact surface. That's where corrosion starts to occur. I've always gobbed any kind of dielectric grease on/in connectors except those that are gasketed and watertight. For gasketed/watertight connectors I will use a contact cleaner and place a super minimal amount of grease on pins and at the tip of sockets. But for the typical pin/socket connectors and ring terminals, I clean them, wash out crimped areas with contact cleaner, and re-squeeze the crimp, clean the contact surface and nut/bolt with emery cloth or sandpaper until they shine, grease it all up, and refasten the connector and/or rebolt the ring, then grease over it neatly, but completely. BELIEVE ME, any micro burrs and general contact of the connector and connection will create their own contact and won't even show a fraction of an ohm of resistance. Once done and hooked together and/or bolted, I gob a 'neat' amount of grease over the whole chebang and wipe off excess. Years later the area has some dirt and dust caked into the grease, but wiping it off and disassembling it reveals just what was left before application of the grease. Sometimes I'm amazed at how clean the contacts still are. ZERO, and I mean ZERO, corrosion, and very obvious scratches and clean spots where 100% contact was made.
This method keeps water and air pretty much out. Vehicles are the worst in terms of corrosion and contact degradation because all of the elements are there: moisture, dirt/debris, oils, brake fluids, antifreeze, road salt and deicing chemicals, hot and cold temperatures, and, of course, electrical voltages. (and bad contacts that heat up and cool, expend and contract metals....)
I bought a 2012 Wrangler with 82K on it this past January. It was/is in amazing shape. After a couple of mud baths it started popping off codes like the whole thing was gonna blow up. Of course I panicked and started looking at what they were and replaced a few sensors at little expense. Given the age of the Jeep, I figured why not? After talking to the very experienced folks at Endangered Species in Holyoke, MA, I was encouraged to clean every ground I could find, including ones under exhaust heat shields. The fellow at the counter has a few samples of ring connectors with 3-4 sensor ground wires squished onto one ring and bolted to the block to show me.....it's a very common problem to have dirty/corroded ground connectors. So, before I did what I was advised, I started measuring resistance and was amazed how I'd have 6-10 ohms resistance on measurements from battery ground to a block or chassis ground connection through a wire that was 3' long!
So I started cleaning...and cleaning. I even ran some braided wire grounds between the chassis and engine block. The infamous 4 sensor grounds to the ring connector/engine block behind the passenger side exhaust heat shield? It wasn't too bad, but I cleaned it, resqueezed it, sanded the ring and mount area shiny, remounted it, and ran a thick battery cable from the chassis to the same bolt on the block. What was a few ohms resistance turned into very near zero....like .03 ohms instead of 3-6 ohms. From the battery ground to any spots on the chassis or engine block, they're all comparable, any reading negligible.
I've had NO CEL's, mileage has improved, as if the vehicle is brand new. The cam position sensor and knock sensor I replaced were inexpensive. I even kept the old cam position sensor because it likely was NOT a problem...maybe I'll need it someday.
I respect anyone who feels di-electric or conductive grease is the only way to go...if it works, it's great. My problem is that when conductive grease flows, so does the electricity. The application is needed in some areas, but I'm not sure about vehicles; others may be. Di-electric? I've never seen it flow anywhere, but under extreme heat, it may, but so what? Something will get dirty.
I saw a Jeep at a meet & greet event...beautiful diesel model. Under the muddy hood was a muddy engine. ALL contacts were dry and bare with nothing protecting anything. The battery contacts were dry and grey. I showed the owner and told him that nothing is protecting the actual contact surfaces, and the battery terminals and connectors will soon be glazed over at points of contact. In time they will heat up creating little corrosion and resistance, then more corrosion and larger resistance, and efficiency will go down, and as stated above, it's happening everywhere there are chassis and block contacts. He saw it, and offered that he'll remove the battery terminals and clean, remount, and grease them, then at least coat the chassis contacts and whatever he could get to. I showed him mine and even with the grease on them, they looked cleaner and were definitely more protected than his. he got it. I wonder if he'll be looking to sell his in a few years....
