I have a 2015 JKU AEV JK350 (aev 3.5" lift, 35" tires). My understanding is that the biggest advantage with the AEV built vehicles and AEV lift kits is that they are geometry correct lifts. With having a geometry correct lift, my understanding is that you retain the factory control arms and factory alignment specs and not have to worry about adjustable arms and track bars.
Is that correct?
The reason I ask is that I am in the process of checking all my suspension bushings to see if any need replaced (jeep has ~85k miles) and came across a really good deal on the mammoth adjustable front and rear control arms on extreme terrains website. Basically I could get the control arms for less than I could get a poly bushings kit for in the factory control arms. Just wondering if there is any real advantage in this instance to swapping out the arms completely as opposed to just replacing bushings in the factory arms.
Is that correct?
